pressue relief valve on WD
CWells View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CWells Quote  Post ReplyReply Direct Link To This Post Topic: pressue relief valve on WD
    Posted: 23 Oct 2010 at 12:14pm
Can anyone tell me where the pressure relief valve is located on a WD?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2010 at 12:40pm
Are you talking hydraulic, engine oil or what?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CWells Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2010 at 3:35pm
Engine oil pressure relief valve
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2010 at 4:35pm
Hi Curtis, The engine relief valve is on the right side of block just above the oil pan. It's under a big (takes a 1-1/8" wench) plug. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2010 at 4:37pm
It is right in front of the dipstick hole. About a 15/16" hex with a spring and a ball inside. My WC had a couple washers stacked behind the spring but after replacing all the bearings including cam brgs, it has good pressure without the washers now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2010 at 4:44pm
Dang Charlie, I'm getting forgetful in my old age. lol
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2010 at 5:04pm
Don, What do you mean? I had to go out and look at my tractor to remember and I might still have gotten it wrong. LOL I musta been typing when you were cause I refreshed the page and there were no replies so I started typing.
