Chute electrical motor 720 snowblower
dertz19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dertz19 Quote  Post ReplyReply Direct Link To This Post Topic: Chute electrical motor 720 snowblower
    Posted: 07 Nov 2023 at 5:32pm
It looks like the electric motor that rotates the discharge chute on the blower for my 720 has gone out. Any recommendation on a replacement? I assumed I'd have to have it rebuilt but I came across an aftermarket made by Flip Manufacturing that looks like the same thing except for a slightly different electrical connection.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2023 at 6:56pm
There was a thread on Simpletractors.com that contained the information  you are looking for, if my memory serves.  ~ Orangeman
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2023 at 8:19pm
Window regulator motor from early 70's chevy car works.  Does have a different two wire hook up and may have to run ground wire to frame.  I changed the wire ends to the female spade terminals and worked well, didn't loosen with vibrations.  Did it on the snow blower I had, IBWD Mike has it now.
I got the wrong side and think just swapped the gear head from one to the other.  The left one is the salvage yard item.
IB (restoring), MF GC1705, MF 2705E
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2023 at 9:07am
I can verify what the man did works just fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2024 at 9:47am
I think it was a rear window motor from a 70's Jeep that was the perfect swap.  Somethin' like that........Confused
Steve@B&B
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2024 at 9:57am
I used a LH window motor out of a Buick Regal quite a few years ago.  Only had to drill one new hole in the blower mounting for the motor. For me it was a very reasonable replacement option.
