valve guide installation |
tractorboy
Joined: 03 Oct 2009 Location: southern Va Points: 475 |
Topic: valve guide installationPosted: 05 Nov 2023 at 4:24pm |
Getting ready to install new valve guides in son's D10 III, rebuild. The new ones from reliance, seem to be knurled at one end. My question is, is that the end that's at the top ?? Also has a line bout 3/4 '' toward one end, I guess that's for depth but thought I'd follow the manual, says use straight edge & make them even with valve cover mating surface. Any help appreciated, keith so. va.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5164 |
Posted: 06 Nov 2023 at 6:51am |
I've made a bushing the correct length that will only allow them to press in to the correct height.
tractorboy
Posted: 06 Nov 2023 at 11:12am |
Knurled end at the top???
PaulB
Posted: 07 Nov 2023 at 6:24am |
The Knurling would go into the head. That's what holds them in place as they are most likely made in China somewhere and they didn't convert inches to MM correctly. The OEM guides are the correct size and smooth from end to end.
tractorboy
Posted: 07 Nov 2023 at 5:33pm |
The knurled part is on the INSIDE of the valve guide, still want to know if that end goes up???
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2427 |
Posted: 07 Nov 2023 at 9:40pm |
In my opinion, yes.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54468 |
Posted: 08 Nov 2023 at 4:04am |
I would assume that it goes in knurled side to the inside. you may want to search the internet using more specific terms that I did. I entered "installation of knurled valve guides" into YT and one of the first videos to come up was this:
Les Kerf
Posted: 08 Nov 2023 at 8:18am |
Yikes! Brand new valve guides that are already knurled?!? ![]() Knurling valve guides was a common way to get a bit more life out of a worn-out engine when parts were expensive and labor was cheap back in the bad old days and everyone was happy if a car engine went 60,000 miles. Perhaps I am missing something or I am merely confused
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6091 |
Posted: 09 Nov 2023 at 11:24pm |
I'll second Les on this... knurling on the INSIDE is done as a temp fix for wear.
if it's on something from China, I'll bet that what they did, was pull out guides from an old head, and copy them... knurling and all...
wjohn
Posted: 09 Nov 2023 at 11:58pm |
The AGCO valve guides I bought for my WD had spiral marks inside of them - I presume for oil control, with no seals?
The old ones I took out also had them.
