WD-45 eccentric clamp blocks
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 eccentric clamp blocks
    Posted: 31 Oct 2023 at 7:45pm
Picked up another WD-45 a couple months ago and started today to mount a better set of rear rims on it. Out of the 8 eccentrics it only had 2 clamp blocks per side. I need at least 4 more blocks. Anyone have any spares laying around? Thanks much.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2023 at 8:18pm
No sure if I understand correctly. Are you referring to the wheel stops and the long bolt that goes thru the rail on the rim. If so only two of those were used on one rail only.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2023 at 8:55pm
I believe what he is referring to is what the Parts Catalog calls
Eccentric Pin Block, located inside the Eccentric Body and up against the Eccentric Rim Retaining Pin.
G
Post Options Post Options   Thanks (1) Thanks(1)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2023 at 8:56pm
I’m referring to the clamp block that the cam screw tightens against the rails. It’s the block that has the half moon milled on one side.
Edited by sparky - 31 Oct 2023 at 8:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2023 at 9:06pm
Gary out typed me and he’s spot on what I need. Thanks
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2023 at 10:00pm
Steiner Tractor has them.
tom51 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2023 at 10:00pm
Contact Lon Sager he has everything you need
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 8:22am
X-2!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 2:32pm
How do I contact Lon?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 6:41pm
Forum member   Lon(MN)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 7:22pm
Thanks for clarifying. Yes I see them in the owner's manual. in the parts section.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 9:53pm
Sparkey you can email Lon at lselkriver@gmail.com he has what you need
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2023 at 7:05am
I have those parts and received your private message. Send me an email so I can send a picture. lselkriver@gmail.com. I just cleaned up some nice ones yesterday.
Thanks for the referrals.
http://lonsallischalmers.com
