Modified B , but hard to spot
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Topic: Modified B , but hard to spot
    Posted: 27 Oct 2023 at 3:07pm
This B looks typical, just missing the battery box.
Look closer.
Lots of mods here to allow a short statute user to operate it.
It is also for sale. Not mine.
https://www.facebook.com/marketplace/item/176231615480332/?mibextid=2JQ9oc
Edited by KMAG - 27 Oct 2023 at 3:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2023 at 3:15pm
I have cut 6 inches off the steering column to move the wheel forward, closer to the gas tank... But this one looks like it is 18 inches shorter and several inches cut off the gas tank ??? ..... Would like to see a view of that further back !..... That is small enough for a KID to drive !.... Must have been 4 1/2 ft tall ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2023 at 3:16pm
maybe he just wanted to move FORWARD with his weight.. Looks like he moved the steering, seat and pedals ALL forward 12 inches .... Maybe not SHORT, just wanted to reposition FORWARD ?
actuall lookes like the seat sets up against the left side fender.. Steering column is not original location... might actually be on the LEFT side of the  torque tube and mounted OUTSIDE of the gas tank... From this angle it looks like it runs THRU the gas tank..  Moving OUT to the left would be the only way to push the column up at that angle as the factory setup is already  close up against the gas tank
Edited by steve(ill) - 27 Oct 2023 at 3:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2023 at 4:57pm
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2023 at 10:16pm
Steering column is centered.
No one mentioned the transmission shifter.
I'd like to try out this B.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2023 at 5:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2023 at 5:59am
D-10 prototype model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2023 at 6:24am
I don't understand why sellers don't have LOTS of pictures, at least 4 (all sides), in they're ads ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2023 at 7:58am
steering column on a B will not set at that steep of an angle. ( unless the photo is all distorted due to the angle)... Either the back half of the gas tank has been cut off ( cant see that tank ?) or the column sets to the side.. and the mounts on the torque tube do not allow that kind of angle on the shaft.... trying to make it look like a D10 is a good explaination.
photo from above
stock B steering column
Edited by steve(ill) - 28 Oct 2023 at 8:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2023 at 8:10am
send him a note to get a couple more photos of the tank and steering !!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2023 at 9:07am
Dr
I had the exact same thought - a D-10 / D-12 Proto Type.
It might have a D-10 or 12 Steering Box.
The short Gas Tank might be because it has been moved forward under the hood.
The Throttle Lever and Linkage is very similar to D-10 / 12.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2023 at 9:11am
so it's a steal at $1000 for someone, if they undid what he done ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2023 at 12:15pm
Yea... would be nice to know if it came BEFORE the D10.... or was copied later... but it sure looks like one.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2023 at 4:46pm
He is only a couple of minutes from me. I have no use for it but if someone wants it, i will go grab it until you can arrange transportation
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 1:51am
Could be some interesting history in that one.
Maybe started with a rusted B tank and a D19 parts tractor to scavenge from .
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 6:24am
Why would a D10 prototype be sitting on the early style B final drives?  You'd think they would have used a later B with the 5 bolt hubs.  Could it be an IB steering gearbox?  They sat at a higher angle than the regular ones.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 7:30am
I doubt very much that it is  D-10 proto. Just someones better idea of what a B could have been and maybe got inspiration from seeing an actual D-10-12 series.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 8:08am
I'll bet the D-10 / 12 Proto type was a combination of a CA and D-14 / D-17, since they were in Production.
The 'C' had finished in 1950 and 'B' finished in 1956.
G
This page was generated in 0.089 seconds.
