Question for the plow guys
Darrell Roberts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell Roberts Quote  Post ReplyReply Direct Link To This Post Topic: Question for the plow guys
    Posted: 22 Oct 2010 at 12:13pm
Have a set of 3 bottom 14 inch snap coupler plows that are going to need points soon. I've read on this topic before and I know that there are diffrent points depending on the molboard that is on the plow. I cleaned mine off a little looking for the number and can read a very faint decal on the back of one that appears to have the number 262-14 or 242-14 on it. Does that sound right and if so does anyone know where I might be able to get a set of points at? If all else fails I can always take one of the old points off and see if there's a number stamped on it.  Going to a local plow day tomorrow with the D14 and plows, supposed to be nice weather.  Thanks, Darrell
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 1:04pm
My 1968 plow bottoms book has only 226 beginning with 2 and three digits. Has only 332, 362, and 372 ending in 2. There are 24, 25, and 26 bottoms.
Generally there are several shares, points, shears, or blades (called all these things on different bottoms, for the same part) for each size and number bottom. A few are shared between multiple bottoms (most often different bottom numbers but common shares for one piece and slatted moldboards). The many different shares have different lengths, different materials and different amounts of suck.
I don't have any connections to any sources of plow parts.
Gerald J.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 1:24pm
Darrell, there should be a part number stamped on the back side of the bottom.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell Roberts Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 2:10pm
OK, thanks for your help. I'll take a closer look and see if what I can find.
This page was generated in 0.122 seconds.
