Transmission Fluid WM Dozer
dhans10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dhans10 Quote  Post ReplyReply Direct Link To This Post Topic: Transmission Fluid WM Dozer
    Posted: 19 Oct 2023 at 3:29pm
I have a 38' wide track dozer and I'd like to replace the transmission fluid.  Two questions.  Where is the easiest way to drain and then fill with new?  The manual indicates the rear of the unit for both, but that doesn't make sense for filling only draining.  Last question is what kind of fluid do you use in yours?  This won't see winter operation if that helps.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 12:06pm
For what its worth. My dad ran a K when I was a kid, it leaked so he ran 140 rather than the 90 he had been using. Never had a bearing failure in trans or final drive. Central coast of Calif, so never lower temp than the low teens.
This page was generated in 0.227 seconds.
