WTB 2300 disk gang bolt |
Mikez
Topic: WTB 2300 disk gang boltPosted: 18 Oct 2023 at 10:52pm |
Hello
I’m looking for a gang bolt for 2313. 13’ wide disk. The parts book says the gang bolt is 74-1/2” long. Original part number 586971. Thanks
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 19 Oct 2023 at 5:48am |
Send the specs to Shoup and have them make you one.
Mikez
Posted: 19 Oct 2023 at 6:14pm |
Thanks Paul but they won’t do hexagon shaft.
Wondering if you switched to square and square bearings
Mikez
Posted: 28 Oct 2023 at 10:04pm |
Bump
Mikez
Posted: 05 Dec 2023 at 8:37am |
Btt
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4874 |
Posted: 05 Dec 2023 at 9:36am |
Weld what you have. V it out to just little point, then start with 7018. Give it plenty of time, spend more time cleaning slag than welding. Chip and then wire wheel, make it shin. Then another pass. Lay it in a piece of angle iron, keep turning it at each weld pass to keep it straight. It is hours not minutes spent to get it right.
I have welded the round axles in a medium heavy duty offset drag disc. I have never broke one of my welds, and I am not one of the worlds best welders. I welded them to have a nut on both ends to make replacing broken blades faster. I farm over many rocks.
Mikez
Posted: 26 Dec 2023 at 11:13pm |
Ours is bent not broken
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 27 Dec 2023 at 6:47am |
Could it be straightened? 20 ton shop press might do it. Or weld something to it so it won't roll, then wail on it with a sledgehammer. Another option would be to cut a v notch into the high side, then pound it straight. Then weld the notch full. Depending on the bend, might have to notch it in a couple spots.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
Ron(AB)
Posted: 30 Dec 2023 at 11:24pm |
I second straighten it.
I had a bent shaft on a 2600 disk and straightened it on my press. It works good. |
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
