D17 Mystery Part
All Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote All Orange Quote  Post ReplyReply Direct Link To This Post Topic: D17 Mystery Part
    Posted: 15 Oct 2023 at 3:23pm
I am 99% done with a FULL restore of a 1958 D17  I was very careful to label everything as I took it apart.  It is all back together and i have one part left over.  I have looked everywhere and nothing stands out.  It looks similar to the bracket that holds the brake lock.  Any help would be appreciatd.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 5:13pm
Brake rod support maybe??
leoversteeg11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leoversteeg11 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 5:31pm
Was it bolted to the cylinder head, for lifting? What are hole dimensions? And is the hex pattern worn into the piece, or factory made it that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote All Orange Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 9:48am
It would not have been used for lifting.  The bracket is only 2 inches long.  The hex pattern appears to be original but you never know with these old machines.  It closely resembles the bracket for the brake lock but not exactly.  I will hold on to it until I figure it out.  Does not appear to be a critical part.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 10:11pm
How LARGE is it?  Large enough to hold the rear work lamp on??
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 9:44pm
I just restored my series 1 and I do not recall that part.
Edited by AC720Man - 18 Oct 2023 at 9:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 6:11am
heck I'm impressed you only have ONE  leftover part !!!
rear work light mounting bracket sounds good, as there's only ONE of these 2" long parts
perhaps a 'parts picture' may show it ???
like others, I'm curious, so hopefully someone will KNOW what it is !!
