D 21
Allis Guy 17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Guy 17 Quote  Post ReplyReply Direct Link To This Post Topic: D 21
    Posted: 13 Oct 2023 at 5:54am
Hey guys was hoping for a little help . Have a d21 and need the tube from hydraulic filter to rear end housing. Any help would be great thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 2:48am
Theres probably a few around - but- you may try to put a hydraulic hose in its place , pia. with fittings etc but would probably work
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 7:41am
Try running that part number through an agco dealer. You might be surprised.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Guy 17 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 7:54am
Thanks guys plan is to use a hose . Tried running part number no longer available
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 1:46pm
NLA yes but did they do a national search for a NOS in somebody parts bin?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 5:01pm
Steve that’s a great suggestion, Brenda at SLI has found several items for me that way. She searched for me, I didn’t even ask her to. Some dealers will go above and beyond to help locate parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 9:15pm
I'm in IL. My dealer found me the only part left in the country according to dealer info in Washington State. Called them and bought over phone including shipping. Even supplied phone #.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 6:59am
That’s a new one. Buying allis chalmers parts from Nissan
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 7:05am
I’m throwing the BS flag.  Think that’s a bot or scam post!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 2:52pm
I tried searching everywhere for this line when I got my D21 a few years ago - no luck.  Have not found a used one either.  If I had one to use as a pattern, my local hydraulic shop could probably bend one up.  Did that for some of the lines on my 175 back in 2015.  Currently running a flexible line, but I cannot leave it on there when I restore the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 6:25pm
What ends are on the line?  JIC?  What is the number? 239579?  Does anyone have one off to get good pictures and dimensions from? West Dakota utilities in Mandan nd should be able to build it if it has jic ends.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 9:06pm
Is it just me or did that bs buying hyd line from Nissan post disappear
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 9:12pm
The report button works!
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 6:39am
Does that last post from alvina28 seem like a bot?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 6:44am
I’d say so. I received one in pm over night
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 7:47pm
In response to the original post, some hydraulic shops can make steel lines like that. I had a steel line reproduced for a D14 years ago at Clarkson Power Flow in Kansas City, worked perfectly and looked original. Mine had rusted through. If you have the original tube they could probably produce a copy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 11:19pm
Gentry welcome to the forum. Is D14 your only orange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 11:21pm
Wonder why this particular post is getting so many scammers. It’s not in classifieds and doesn’t say wtb in heading. Goodluck I ran the part number and don’t have anything
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Guy 17 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 5:50am
Got the tube off and it is a puzzle the one end is a jic fitting up by the filter housing . The other end that swivels but threads directly into the housing here are the pics any help getting an original or reproduced one would be great
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2023 at 10:06am
Looks like a male pipe swivel.  Pretty common fitting if it is.  Notorious for leaking after a while though, as they just rely on an internal o-ring to seal.
Hurst
1979 Allis Chalmers 7000
5800 Hours
