Allie charmers 8010
Bryandee11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryandee11 Quote  Post ReplyReply Direct Link To This Post Topic: Allie charmers 8010
    Posted: 07 Oct 2023 at 9:20pm
Hello all. New to the forum and tractors. I recently leased a property that has an allis charmers 8010 on it. It was running recently. The person that had the lease before me was bitter about losing it and when he left he stole the batteries out of the tractor. I cannot seem to wire it correctly to get it started. There is only a black cable by the battery location. It has two terminal clamps I’m assuming to go to two batteries. I cannot find a red positive cable. Does anyone have one that might be able to help me with some pictures of what the wiring should look like? I’d like to get it out of the field and under the barn before the snow. Thanks Bryan 385-383-4220
Edited by Bryandee11 - 07 Oct 2023 at 9:36pm
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 10:49pm
Go back to the starter and look to see what color of wire is on that…
It may have the “bare” style of ground which is flat gray/ metal look and a black positive style cable.
1955 AC WD45 diesel with D262 repower, 1949 AC WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 10:51pm
It may have a clutch safety switch which means you have to hit the clutch all the way to the floor before it will crank over…
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2023 at 5:39am
After 40 years of others working it, things may not be OEM like anymore. The POSITIVE battery cable was never red, always black. It connected to both + posts on the batteries and then went to the starter solenoid stud. There were two shorter negative ground cables on the battery tray. The starter excite wire is 10 or 12 gauge WHITE in color. It comes from the safety switch on the PTO valve on the rear of the tractor and before that, the safety switch on the clutch pedal. So, there are TWO safety switches that have to be closed.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2023 at 9:00am
Bryan, welcome to the AC forum.
Here’s a link to a previous AC 7020 wiring diagram. It shows the battery setup. It may not be exact but it’s an older series version of the 8010? So it might help?
Batteries(2 - 12v) hooked up in PARALLEL, not series for 12v to engine starter.
Battery size is BCI group 31, 650cca minimum -up to 900cca.
https://www.allischalmers.com/forum/7020-wiring-diagram_topic164082.html
Edited by AC7060IL - 08 Oct 2023 at 9:16am
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2023 at 10:06am
Should have 1 black cable - that is the positive terminal.  There should be a braided ground cable around the battery case somewhere - that will be the ground strap.  Takes 2 12 volt batteries connected in parallel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2023 at 10:22am
Geesh why would a + 12 volt battery cable be black ,,  least the battery should have a + on it
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2023 at 11:16am
All of mine are black cept for the 170 which I changed to red
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryandee11 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2023 at 2:10pm
Thank you. This helps
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2023 at 2:20pm
Hope you can save it.  We need all the 8010's to survive and stay up and running that we can get.
gleaner1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2023 at 5:04pm
Interesting that leased land comes with a bonus tractor!!
ALLIS CHALMERS "The color is orange"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2023 at 6:17pm
Ya that is interesting. If you plane to run it much, pick yourself up a operators manual
