HD-16 questions
ThatTractorGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ThatTractorGuy Quote  Post ReplyReply Direct Link To This Post Topic: HD-16 questions
    Posted: 05 Oct 2023 at 8:13am
Hello, everybody...
I posted in another location that I am writing a fiction book about tractor pulling. In my fictional tractor pull, there are 2-wheel drive, 4-wheel drive, and crawler classes.
One of my characters drives an HD-16 in the pull, competing against a Caterpillar D7 and an International TD-18. The HD-16 has a torque converter, and I think that should give it an advantage.
So I have a few questions. I've seen some pictures and videos of the operating station, but not very good ones....
1. Is the tall lever on the left the clutch lever? Is it forward-disengage, rearward-engage?
2. Does the torque converter model have the clutch lever too, or just the straight drive model?
3. I see the torque converter transmission has three gears/speeds. I'm under the assumption that first gear would be the one to use. Is this shifter on the floor like the one on the straight drive machine?
Anything else I should know about the HD-16 with torque converter?
But without faith, it is impossible to please Him, for he that cometh to God must believe that He is, and that He is the rewarder of them that dilligently seek him. Hebrews 11:6.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 8:25am
yes converter tractors had the tall clutch lever until the powershift models came out.
fwd is disengage rearward is engaged
first gear would give maximum push
yes shift lever is same position and lever as gear drive machines just would not have the high low lever next to operator seat
converter tractors turned 100 engine rpm more than direct drive machines to compensate for converter slip
dont have my book with me but it has speeds, maximum pull etc
Edited by CAL(KS) - 05 Oct 2023 at 8:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ThatTractorGuy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 8:54am
Thanks, that helps. there is some data on Tractordata.com for the HD-16, so I was able to get some info from there. This will help it seem a little more authentic.
I would love to drive one some time!
This page was generated in 0.176 seconds.
