i600 tune up kit
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: i600 tune up kit
    Posted: 02 Oct 2023 at 5:49am
Where’s the best time lace to buy a tuneup kit for my I600?
I assume it’s the same as a D15?
I need points, condenser, cap and rotor. Possibly a coil?
Will start and run for a few minutes then start sputtering.
Very rusty inside the distributor .
I cleaned everything up but it still dies out after a little bit.
Points look wore out and condenser is very corroded and rusty.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 7:30am
Napa? That's where I get Echlin brand ignition parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 8:22am
Would be a great time to go with a Pertronix ignition and not t have to worry with finding a good set of points, condenser, or coil. If you do make sure you go with the matching plug wires. For a little more money you will have a better starting and running tractor. My brother switched our D15 over to it and it runs so much better.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 3:13pm
I would make sure your fuel system is in good shape first - no crud in the tank or carb.  Shouldn't need a coil, but I would go with plugs and wires if they look old.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 4:06pm
I checked out the fuel system.
Pulled the carb drain and let some gas flow. Keeps a steady stream and looks clean.
If I let it set a few minutes it starts and runs perfect for a couple minutes then quits.
Let it sit and same thing.
Change me doesn’t help or change the situation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 4:12pm
sounds like a bad condenser... but a coil is also a possibility..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 4:48pm
Don't forget the ignition switch easy way to check it is with a hot wire...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 9:15am
Good point
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 7:29am
I’m giving this some serious thought.
Dies it still require the old coil?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 5:04pm
If I remember right, pertronix needs a coil with 3 ohm resistance...  look it up for sure on their website, I'm sure they have one...
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 5:06pm
As far as I know the old coil can still be used but when I did my upgrade I went to a matching Pertronix coil.
