Roto baler table conveyor problem
TB63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TB63 Quote  Post ReplyReply Direct Link To This Post Topic: Roto baler table conveyor problem
    Posted: 01 Oct 2023 at 7:58pm
I tried to get my roto baler working today after sitting for 4 years. The conveyor on the table will not engage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 8:01pm
Welcome to forum
TB63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TB63 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 8:38pm
Thanks. I should have included more info. The last time I used it it became clogged up and I couldn't get it free.
Today I finally unclogged it and got the belts spinning but conveyor isn't working. I've tried pulling the rope to get it going.
I'm not sure if the twine mechanism needs to be reset or if it is the clutch. Any help would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 12:34pm
There is a replaceable wear piece on the dog lever that engages and disengages the pickup conveyor. When it gets rounded it causes problems.
TB63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TB63 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 5:00pm
Thanks Paul. I took a picture of the part I think you are talking about but couldn't load it on this page. It has a threaded hole in it like something should go on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 6:34pm
Yes: That sounds right. It has a wear pad that bolts on there.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 7:16pm
Before mike finds the part for you, make sure the linksge is free. Stuff loves to set up after 4 years the latch plare could be frozen
TB63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TB63 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 5:08pm
Well the conveyor started working so I decided to try a few bales. After going about 100 feet the baler PTO stopped and the tractor died. Basically the same thing that happened 4 years ago. Then I thought the hay clogged it up but now think something else is getting it into bind. Any ideas?
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 6:40pm
Are the bale forming belts workly correctly? Sometimes the lower belt get caught by the upper belts . That can stall the tractor
TB63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TB63 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 6:52pm
I will check that tomorrow. Thanks
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 8:07pm
There's a brake drum on lower right side. Make sure that the brake shoes aren't rusted to the drum
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 8:53pm
Use a bigger tractor!!
No, wait don’t do that!
TB63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TB63 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 9:20pm
I did loosen the bolt on the brake before I started but I didn't check to see if the pad was rusted. It ran fine and rolled a partial bale before it locked up.
TB63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TB63 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 7:22pm
Hey guys. Thanks for the all the helpful advice. I was able to bale a few today. I took a brass hammer and tapped on the brakes and they popped free.
