7010 Transmission Problem
crossfire879 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crossfire879 Quote  Post ReplyReply Direct Link To This Post Topic: 7010 Transmission Problem
    Posted: 28 Sep 2023 at 5:55pm
I have a 7010 with the 12 speed transmission. I am unable to get into any other gear except for 3rd and reverse because the "throw" of the gear shifter is too much. For example when coming from reverse or 3rd into neutral, you have to have the shifter all the way ahead (where 1,2,4 would be) to be in neutral. Therefore its unable to go into those top gears. The linkage above the floor all seems tight. Also it just started to occasionally pop out of gear. Is there anything else I can check?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2023 at 6:25pm
What is the largest number on your tee handle shifter?? 4 or 5.  You have either a 16-speed or 20-speed Power Director transmission. There is linkage inside the console that you must take the console side panel off (next to the seat) to see. There is linkage under the cab too. Something is very loose and it would take two people to find the problem. There could be a broken bolt holding one of the pivot bearings under the cab floor. There are two of those.
This page was generated in 0.069 seconds.
