Help identify mounted coil tine harrow on FC |
Post Reply ![]() |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Sep 2023 at 8:38pm |
It's on my newly acquired 1400 field cultivator (Chiselvator) and need a few parts for the rear harrow. I can't ID it so I was hoping for some help. Thanks
![]() ![]() ![]() Edited by Lonn - 05 Oct 2023 at 10:08am |
Wink I am a Russian Bot |
I need a hold down spring, brackets and a couple bars that the tines bolt to.
Try again. I hope someone can help. Mainly I need a spring and the plugs on each end of the spring. Thanks
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4734 |
I found without the down pressure springs I like my harrow much better. Trash flowed thru my cultivator only to plug the harrow. Then everything was a mess.
![]() Have you tried looking at McMaster-Carr and find a spring by dimension. But that would still leave you in need of plug.
steelwheelAcjim ![]() Orange Level ![]() ![]() Joined: 06 Dec 2009 Location: Blissfield,Mi Points: 1257 |
Remlinger Manufacturing. Kalida, Ohio.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Thanks guys I will take a look
Post Reply ![]() |
