226 engine
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: 226 engine
    Posted: 24 Sep 2023 at 6:13pm
  Recently bought a WD45 at the end of the engine serial number is the letters  OH.
  what does these letters mean?
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2023 at 9:09pm
Perhaps a rebuilder stamped it OH to signify that they had performed an overhaul?
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 7:12am
H was propane. PA was gas engine.
http://lonsallischalmers.com
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 11:35am
Post the entire engine serial number; perhaps the O is actually a 0?
If the tractor is a WD, the engine number will be WD-XXXXXX  followed by one or two letters.
In this case PA or GA (late) indicates Gasoline,  K (or KA) indicates Kerosene or distillate and H (or HA) indicates "High Altitude".
If the tractor is a WD-45, the serial number should consist of 45- XXXXXX  followed by 1 or 2 letters indicating fuel type. eg: G or GA for gasoline.
I can't find the fuel suffix letters for the WD-45 other than gasoline  but I am going to assume they may be the same as the late WDs.
I can't find any specific letter designations for the WD-45 propane tractors but I see that piston part number 223507 is used for both the WD low octane fuel tractors (5.00:1) as well as the WD-45 Butane, LP gas and gasoline powered tractors (7.2:1). The wide variation in compression ratios must be a result of the 4" vs 4.5" stroke.
It seems I have seen a few other variations in the last two digits of engine serial numbers over the years but, unfortunately, I didn't make note of them at the time.
Sorry for the long post, lot of stuff to cover here.
After all this, I hope you do find an answer to your seemingly simple question. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 6:19pm
   Cleaned the end of the engine serial number better the letters are GH, the tractor is   a   WD45, according to the serial number over 200 hundred was built before it was.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 8:06pm
“..   Cleaned the end of the engine serial number better the letters are GH..”
Is it possible the letters are ‘GA’? That would be more likely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 10:15am
I agree with Tram; by far, the greatest number of WD-45s had GA (gasoline) as a serial number suffix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 6:18pm
  The letter is  a clearly  H.  Could this engine be one built for a high altitude  area?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2023 at 8:56am
Please post the entire engine serial number!
