N-5 R-5 cylinder imput assembly
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: N-5 R-5 cylinder imput assembly
    Posted: 20 Sep 2023 at 5:27pm
Trying to remove the cylinder input assembly but dont have enough room do to the outer sheave hitting the clean grain elevator.
 I have removed the nut and washer from input shaft
  I removed the bolts to the outer sheave ring
  I slid the assembly outward and removed 8  bolts from the back side of the inner sheave
  Everything is loose but I have no clearance to remove do to the outer sheave it's  hitting the clean grain elevator
 Do I have to drive both the inner and outer sheaves inward and leave them hanging on the input shaft while I take off the cylinder input spring assembly?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 8:06am
You might try a search over on thecombineforum.com
This page was generated in 0.033 seconds.
