B starter orientation
DMac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMac Quote  Post ReplyReply Direct Link To This Post Topic: B starter orientation
    Posted: 16 Sep 2023 at 7:00pm
I have a starter from an older b with the push rod and starter button on the bottom. Can I rotate the nose on that and use it on a newer b with the pull rod and button on top, and if so what is the procedure?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 7:06pm
YES you can... as you said, take out the two long bolts going all the way thru the starter case.. Dont take everything apart... just rotate the nose 180 degrees relative to the switch and put the bolts back in. .... the GROUND BOLT/ anchor should still be in the right place in the nose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 7:11pm
https://www.youtube.com/watch?v=VpIo-QgudMQ
look here about the 4 minute mark... just dont pull the nose out more than 1/4 inch so the brushes on the BACK dont come out of the holder... DONT take off the back end.
DMac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMac Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 8:48pm
do you just cut that little alignment pin off ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 9:19pm
there may be a hole on the other side to put it in...  if you look at the movie at 6:15 you can see him slide the armature back into the nose.... So you COULD pull the nose all the way off of the housing and look at the pin, drill a hole, etc.... Just TRY not to pull the rotor out of the back end or you will have to reassemble the brushes..
Not a big deal, but kind of a PITA if you have not done it before..
Edited by steve(ill) - 16 Sep 2023 at 9:25pm
DMac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMac Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2023 at 8:11am
ok ill give it a try thank you!
This page was generated in 0.046 seconds.
