Long wheelbase 7020
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Long wheelbase 7020
    Posted: 13 Sep 2023 at 10:50pm
Looks like a long wheelbase 7020 on tractorhouse. Interesting looking. Check it out
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 6:30am
That took some fabricating. I wonder how that would ride? I’ve seen guys reverse the front axle, but I’ve never seen them do a modification like this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 7:42am
Some short-line company made those (maybe not that one) many years ago that you swapped out the center tube for a repositioned one and then used your old knees. Seems like the square tube was just ahead of the rear pivot point instead of behind it.
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 9:03am
the one with 8988 hrs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 9:16am
Yup cedar falls Iowa
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 9:27am
how far forward was the axle moved... i had a hard time seeing much difference ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 9:45am
Like I say, the square tube is ahead of the rear pivot, so I think it was about a 10 inch extension of wheelbase.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 10:12am
Any ideas on why this was done? As the Doc has said a company did more than just one or two.   As ride quality was already mentioned, from experience a little bit makes a lot of difference.
There was a good sized construction company here in California build 1000's of miles of highway.  They became the go to for concrete paving for a time. But after a few years all the expansion joints became high spots. Some vehicles rode much, much better than other many times just to due with the wheel base. Many a independent trucker specked trucks the with the wheel base that gave less bucking rolling over the expansion joints. I was told just 2 inches more or less made a huge difference. The state spend a fortition  planning the concrete for years. Finally in the last 20 years all has been replaced with asphalt concrete.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 10:21am
We had a 8070 in the early 90s that we turned the front axle around on and made it look like that. Dont remember why we did it but I think it was to get clearance for saddke tanks. Wasnt ideal but it worked
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 4:47pm
Doesn’t look horrible. What was the logic I wonder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 9:19pm
Wasn’t there posts on here awhile ago on doing this to 8xxx to make them ride better
MikeKroupa View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeKroupa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 10:09pm
If I'm thinking right DAKON mfg. made those kits to increase wheelbase. John Day Co. in Omaha was one of their distributors. I have the literature piece , just have to find it.,  Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 10:26pm
Oddly, my buddies Ford 8600’s are like that. He flips every one of his around for shorter wheelbase and a tighter turning radius.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 7:21am
Those Fords came either way from the factory.
