D14 oil pan
Mikey Joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikey Joe Quote  Post ReplyReply Direct Link To This Post Topic: D14 oil pan
    Posted: 08 Sep 2023 at 9:49am
I have a CA with a cast iron oil pan. Will a D 14 steel oil pan fit and work properly?
This tractor has a cast iron valve cover also. Was this normal?
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 4:40pm
   Sounds like you have an engine from an older
tractor in your CA.
J Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 5:41pm
Wartime AC engine, VC and OP were made of cast pot metal, as the steel was unavailable due to wartime shortages.  Pretty sure the D-14 pan won't fit, but b, c, ca pans will...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 7:14pm
B, C, CA, RC, D10/12/14/15 all oil pans are interchangeable. As for valve covers The B, C CA & RC will interchange. Only some have 2 bolt holes and others have 4. Use the correct hardware for the number of holes you have. Those that don't know should keep mum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 8:55pm
YEP... You valve cover and pan came off a B or C engine from the early 1940s... Or maybe the entire engine... You could tell from the serial number.
This page was generated in 0.246 seconds.
