|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Best 8030 Alternator |
| Post Reply   |
| DSeries4   Orange Level     Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7533 |  Post Options  Thanks(0)  Quote  Reply  Topic: Best 8030 Alternator Posted: 06 Sep 2023 at 4:57pm |
| Took the alternator from the 8030 to our local shop as it has issues.  They looked at it and mentioned that it is a combination of 2 or 3 different alternators all put together!  The manual shows Neihoff alternators 80 and 100 amp for the tractor.  What size Delco would work best, and would there be any fitment issues? Many thanks! Edited by DSeries4 - 06 Sep 2023 at 5:06pm | |
     '49 G, '54 WD45, '55 CA, '56 WD45D, '57 WD45, '58 D14, '59 D14, '60 D14, '63 D15D, '66 D15II, '66 D21II, '67 D17IV, '67 D17IVD, '67 190XTD, '73 620, '76 185,  '77 175, '84 8030, '85 6080
| steve(ill)   Orange Level Access     Joined: 11 Sep 2009 Location: illinois Points: 88511 |  Post Options  Thanks(0)  Quote  Reply  Posted: 06 Sep 2023 at 5:32pm |
   they list a version of the DELCO 10SI with 100 amp output as a HEAVY DUTY "direct replacement".. there may be cheaper options, but many are not 100 amp output. | |
| Leon B MO   Orange Level   Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2197 |  Post Options  Thanks(0)  Quote  Reply  Posted: 06 Sep 2023 at 7:55pm |
   A factory alt replacement for my 8070 was $1100 at Napa. We did a little searching and found a very nice 100amp unit for less than tha $200. Works fine. Bolted right on. Leon B MO | |
| victoryallis   Orange Level   Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |  Post Options  Thanks(0)  Quote  Reply  Posted: 06 Sep 2023 at 8:55pm |
| Shoup has them since it’s over $200 they got free shipping and they are running a sale currently.   | |
| Unit3   Orange Level     Joined: 17 Oct 2009 Location: NC Iowa Points: 5605 |  Post Options  Thanks(0)  Quote  Reply  Posted: 06 Sep 2023 at 10:42pm |
   Call Carroll Imp in LuVerne, Iowa. They look like a Delco, but I don't know if they are. They have an alt that I have put on 3 of our 8000's. They come with a small pigtail wiring for the dash light and the right size pulley. Best things about them, is price and they work for years. I have tried Neihoff after Neihoff. After 40 years, they just will NOT work anymore. You might want to ask for Kevin and have him tell you what he has put on our AC's. Sorry, I don't know the name of the brand he sells me.
| SteveM C/IL   Orange Level Access   Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8678 |  Post Options  Thanks(0)  Quote  Reply  Posted: 07 Sep 2023 at 8:09am |
   Think my 2 replacements on 8070's are Bosch. Have to run a switched wire to excite. Not overpriced either.
| PeteMN   Silver Level     Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 205 |  Post Options  Thanks(0)  Quote  Reply  Posted: 07 Sep 2023 at 4:36pm |
   I took a Neihoff to the local starter/alternator rebuilder.  He said parts are too expensive to rebuild them.  He recommended a Delco 10SI.  It works fine.   Some bale monitors can have problems with the Delco alternator, not sure if the Delco has a slightly higher voltage output or what, but it can cause a bale monitor to shut down unless you run with the headlights turned on all the time.
| Hurst   Orange Level   Joined: 11 Sep 2009 Location: Midway, Ky Points: 1218 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Sep 2023 at 10:51am |
   Look at the Delco CS130.  It's the newer replacement for the 10si.  Can look up the late 80's-early 90's chevy vehicles for these.  The corvette of that era used one that is supposed to have the same bolt pattern as the 10si.  I have one on my 7000.  Only catch is that the tach reads a little slower with the factory pully (factory was a 10si).  It may match up fine with a Neihoff application though, as I think when switching to a 10si from a Neihoff you have to use a slightly larger pulley to keep the tach reading correctly.  But if you read up about them, they put out cleaner power than the 10si alternators, and tend to be more reliable.  They also put out more amps at lower RPMs if you look at the amp/rpm curves. Hurst | |
     1979 Allis Chalmers 7000
 5800 Hours | |
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
