UC rear hub lugnut?
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: UC rear hub lugnut?
    Posted: 31 Aug 2023 at 3:46pm
I had time today to get the 37 UC out for its annual run about. Noticed one of the nuts that holds the rear rim on is missing. Is that a standard size nut with standard threads or is that something special I need to find on this site?
Thanks
Leon B Mo
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2023 at 9:32am
If I remember correctly, one of what appeared to be a wheel stud, was actually an alignment dowel that was not threaded. It always appeared that one bolt was missing a nut.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2023 at 11:41am
yes one is just a dowel but IIRC the nut is larger than a standard nut for the bolt size
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2023 at 3:27pm
That's kind of what I figured. I refuse to put two different sizes on the same wheel, drives me nuts when somebody else does that then I have to go looking for another socket. So does anyone have the nut for a U rear wheel stud?
If not I'll just go by 10 nuts so that they're all the same for both sides. Thanks again.
Leon B
This page was generated in 0.053 seconds.
