point gap
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Topic: point gap
    Posted: 30 Aug 2023 at 8:19am
My manual says the point gap for a CA is .022 but she doesn't seem to run to well after replacing the points and plugs.  Any suggestions.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2023 at 8:25am
I always set mine at .020". Right or wrong that seems to work.
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2023 at 9:32am
A lot of new points have an anti-corrosion coating on the contact surface that inhibits conduction. Often enough to just cause erratic behavior, but sometimes enough to stop them from conducting altogether.
In the old days running a dollar bill or brown paper bag between the points was enough to clean it off once they were installed. On the last couple of sets I've installed this hasn't been enough - I've actually had to give them one swipe with a points file before they worked well. Just make sure your points file is very clean and fully degreased.
Edited by DanielW - 30 Aug 2023 at 9:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2023 at 9:37am
Can't hurt I will give it a try.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2023 at 10:28am
Oh yes it can hurt. Point files should never be used! The problem with them is they remove the Cadmium plating that's on the contacts to keep corrosion down. When you file the contacts, you start to remove the protective Cadmium plating and corrosion immediately starts. As time progresses, along with constant weather changes, (and filing) before you know it, you just caused your own problem all over again, but faster. The best way to remove the cosmelene off the contacts is either TV tuner cleaner or Brakekleen. A little spritz, pull a rag through em' and they're nice n' clean and ready for service. (providing they're not Chinese points) The old dollar bill or brown paper bag trick worked great. Points should be set at .020,  In some cases, if an electronic ignition is used in lieu of the points and condenser, the plug gap can be widened a fuzz for a little better spark performance...  I believe some of our customer's set the plug gap at .040.   HTH
Steve@B&B
Edited by Steve in NJ - 30 Aug 2023 at 10:30am
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2023 at 9:57pm
GOOD advice Steve !!!!
We are loosing that tribal knowledge as you have shared.
I use electronic ignition on most of my in service equipment but still have many with points. Most of them SIT and corrode. As you suggested. DO NOT use a File !!!
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2023 at 6:45am
Never had or used a point file
My question is why do they make/sell such a thing? Thanks
Les Kerf View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2023 at 7:37am
Well, I'll be the contrarian here Tongue
Back in my VW Bug days I ran two sets of breaker points for over 100,000 documented miles; at tuneup time I removed one set and swapped in the other set, then I honed the first set using a little diamond hone (the pocket kind made for knife sharpening) and set it aside for the next tuneup. I never replace a condenser unless it fails.
This was all recorded in my little log book that I kept in the jockey box. I still have several log books and also my last Bug that is on my long list awaiting restoration (after my late Father-in-law's WD tractor).
This only works on quality points that have enough material to actually have anything left after filing. Most new points nowadays just have a thin coating that simply disappears when filed.
Filing points was standard practice for many decades before our throw-away society got too lazy to pay attention and actually put the effort into making quality products and then maintain them properly.
There is absolutely nothing wrong with filing quality points, but good luck finding a decent point file; this is why I switched to using the diamond hone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2023 at 8:11am
Thanks Les,that makes sense.
wjohn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2023 at 8:55am
If cleaning doesn't do it, check the ignition timing now that you have the new stuff on there set to the right specs. I've run into a couple of tractors where the timing had apparently been pretty far out, and replacing ignition components (bringing points gap back to spec, putting on a new rotor that has no play on the shaft, etc.) seemed to have altered the timing just enough that it became really obvious that something was off.
Last one I did was a Farmall Super C that turns out was firing at 55 degrees before TDC after I replaced all ignition parts. Spec was supposed to be 30 degrees. I'd guess it may have been running at 45-50 degrees for years with the old worn out stuff. Ran much better after I corrected the timing, with the new parts.
This page was generated in 0.077 seconds.
