7010 Leaking Tranmission Fluid
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Topic: 7010 Leaking Tranmission Fluid
    Posted: 17 Aug 2023 at 10:00am
I can't really tell where it is leaking from but I am losing about a half gallon after working the tractor for about 15-20 hours.  I have 16 speed Power Director transmission.  Any hints on likely suspected part failures that I should start with or even where to look for the leak?  I see oil on the underneath side but no leaking while it is sitting still.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2023 at 10:49am
It could be several things, If you own a pressure washer I would give it a super good washing and let it dry for a day than take it out and work it for about 20 minutes and look then see if you can pin point the leak.
You may find you have several small leaks.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2023 at 11:53am
Thanks for that suggestion.  It will be a week or more before I can do that.  My son "borrowed" my power washer a month ago and so I have to track him down and get it back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2023 at 9:03pm
If it is running down left side of transmission, could be dip stick braking off.                           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2023 at 9:04pm
Dip stick tube.                  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2023 at 8:30am
Thanks for that hint.  Never thought about that.  I hope to get to the bottom of it in a week or so.
This page was generated in 0.155 seconds.
