Hydraulic cables
allis/cattle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis/cattle Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic cables
    Posted: 12 Aug 2023 at 2:16pm
How is a person supposed to run the hydraulic control cable from the valve to the handle on a 7040 with serial number 1982? I got a cable from ago but it seam short. The tractor has triple remotes. This is the third cable I’ve put on in 10 years . Bunker hill cable is not an option cause they don’t ship to Canada
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2023 at 7:54pm
If it still has the smaller ,3/16 size cables, then the tallest lever uses a different cable than the other two levers.  Tall lever use 70269207 and the other levers use 70268511. The larger,1/4 inch cables, are the same for all three levers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis/cattle Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2023 at 9:30pm
I knew that part I’m just having trouble routeing them properly
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2023 at 6:12am
Routing ?? They connect to the appropriate lever and pretty much go straight out thru the rear cab wall and curl around to the valve. If your cable is too SHORT, it ptobably won't reach.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2023 at 6:59am
Yes,the route should be the same as the old one that was taken out and very similar to the other remote cables already there. A new agco cable probably has a part number on it to verify that it's correct for your application.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2023 at 7:59am
How did you replace it, the previous times?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis/cattle Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2023 at 4:04pm
I just managed to get it the other times. I did figure out today that my #1 lever was connected to #3 valve so I swapped them around and it’s ready to go
