HD6G brakes adjustment
Jhilton69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Topic: HD6G brakes adjustment
    Posted: 04 Aug 2023 at 7:55pm
Hey yall spent 2 days going through all the topics and didn't see anything about the brake adjustment. The adjustment under the floorboard is maxed out. How do I get the the band adjustment in the rear housing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2023 at 2:26am
Under the seat area should be a domed cover on both rear cases , remove the cover (2 bolts) and band adjuster should be there . 3/4 hex nut , tighten that to bring band closer to  drum . A few turns of it should tighten band
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2023 at 12:52pm
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2023 at 7:52pm
The rear housing of the HD6 is the same as HD5  - so info on either will help
Edited by Coke-in-MN - 08 Aug 2023 at 8:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2023 at 9:09pm
Thank yall
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2023 at 5:43pm
Well found the cap this is what it looks like. Apparently someone in the past tried to cut the bolts instead of taking thier time and doing it the wrong way. Started raining on me so I had to come inside. Anyone know a place I can get a new cap from this one has a hole in it. They did the same thing to the bolts on the other side as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2023 at 2:45pm
Don't think i saved those of rear housing I junked .
Might try cutting a plastic bottle and covering them with it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2023 at 4:19pm
Last night while I was trying to sleep which doesn't happen often I was thinking I got an old cat out here and was thinking bout cutting the flat section of it and making 2 boxes to replace them with. Are there gaskets that go under them?
