Slow remotes
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: Slow remotes
    Posted: 18 Oct 2010 at 9:59pm
 My remotes seem really slow on my 7060. Its missing the dials under the seat to speed them up. My question is if I reach around in front of the remote blocks and turn the screw, can I turn it too far and does it go round and round or only a partial turn? It also makes a rattling sound when I use them, it sounds like its coming from under the cab on the right side. thanks
Edited by 7060 - 18 Oct 2010 at 10:01pm
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 4:30am
I think they go all the way around,my 7060 had the lever installed backwards,the rabbit is slow and the turtle is fast.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 6:17am
They turn in a complete circle.......put the LONG side of the roll pin handle down to be fast or the long side up to be slow.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 1:23pm
the rattling sound can be the load checks bounceing in the valve.  If it isnt real loud I wouldnt worry about it.
Brad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 6:09am
Check hydraulic fluid level, ours rattles when fluid is low.
This page was generated in 0.586 seconds.
