Steel wheel WC for Plow Day.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: Steel wheel WC for Plow Day.
    Posted: 18 Oct 2010 at 9:41pm
I am setting up my factory wide front on full steel for a plow day. My question is, on the rear, I am using the old tip-toe type steel. Did the old timers put wheel weights on steel wheels to plow with? I have a set of 161's I can put on if it is necessary. I know in the past with rubber and no ballast, I had some trouble with traction. Maybe some of you old timers can help me. I am not quite old timey enough to have plowed with steel.  Dave.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 9:46pm
I was plowing with this one about a month ago, there was some slippage but not too bad.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 6:14am
I think the tip toes may weigh more than the rubber with no ballast in them?
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 6:43am
I've never plowed on steel, but I've pulled with steel a fair amount, and I don't think you will need any weight, especially with tip-toe.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 12:04pm
I used my WC with tip toe steel at one of Teds shows one year.  I didnt have any problems pulling a two 14 allis plow with no rear weights.  I ran in third, this WC pulled 35 horse on the dyno so its not light.  If the ground is real hard you will want the weight, if its mellow, then you wont need the weight.  Put some pictures on when you get time!!!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 6:08pm
Dave, If we don't get some rain before plow day you might put one set on, but if it rains some the ground will work up nice.
Don
