allis plow shares
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Topic: allis plow shares
    Posted: 18 Oct 2010 at 5:42pm
Anyone know of a source for plow points and cutting edges to rebuild worn plow shares?
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 5:54pm
Mine aren't worn yet but I too wondered if replacements could be had for the future.
MBwcenll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcenll Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 6:24pm
I too was just about to check on this myself tonight.  Replacement edges would work for me.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 6:26pm
First you have to know which plow bottom, then you can search for plow shares. Typically AC made anywhere from 3 to a dozen different shares for the same bottom, but the didn't work on other bottoms.
To identify the bottom you need to find a part number on the frog, moldboard, shin, or share. Then those with plow bottom books can identify the bottom and provide part numbers for shares that will fit.
Gerald J.
RSponenberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 7:31pm
Im looking for points ,shins and trash plates ( cover boards ) for a #387 in 16"....
Thanks Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 7:49pm
Shoup www.shoupparts.com, probably Sloan Express, www.sloanex.com, Valu-Bilt, www.valubilt.com and others have shares, shins and trash boards for #387 bottom
Gerald J.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 7:42am
I have several new and used shares,covers,moldboards ect. Not sure just what I have. 785-353-2392
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 7:57am
As far as I know the only sources for the weld on edges and points for the older type shares is auctions and swap meets. We have cut edges from new throwaway type shares and welded them on and made up points from small excavator teeth. If you are looking for throwaway shares then you might be able to find them at the places Gerald suggested. We have in the past drilled new holes in frogs to accept a share that is available. The choices are narrow now, and get narrower every day it seems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 9:56am
Ray, list the part numbers of those parts and we can identify the bottoms they fit.
Gerald J.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 9:59am
$ 3.oo each plus shipping I have 17 left. Send me a PM Frist come frist serve.Thanks
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 10:06am
There is a company out here that makes the hardened edges and points that you weld on...will try to find the info. Welding on hardened points for chisel plows is a big business out here in wheat country.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 10:19am
11 left . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 12:26pm
6 left   Thanks Fred
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 12:29pm
Dave and all - Here are some places to try.  They list repair points, shares. shins, landslides, and moldboards.  Hope this helps  -  AL
Edited by ALinIL - 19 Oct 2010 at 12:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcenll Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 9:36pm
Thank you, I did not have time to check your reply untill now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 10:22pm
Thank you to everyone who responded.  Your help is much appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 6:45am
All my points are sold .Thanks Dave and other's . Fred
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 9:13am
Hi: In reply to Gerald J. 347749 New and Used: 71509806 new and used: 572184 new and used: No number but I think for 375 bottom new and used: Old style soft center lays,308802,308864,324890,they all say Allis Chalmers on,all used. All so plow bolts. May have other lays and plow parts. Thanks 785-353-2392
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 11:02am
First three not in my 1968 book which includes the #375 bottom. Wiese says 347749 and 572184 fit a #387 bottom. Nobody on line admits 71509806 even without the 71 modern prefix.
308802 fits 16" right hand 325 and 25 with bolted draw rod breacket and welded frog. Interestingly those two bottoms use the same frogs.
308864 fits a 14" right hand #24 bottom with bolted draw rod bracket and welded frog. Also fits #24 and 124 bottoms with welded draw rod bracket and welded frog.
324890 fits 16" #24 bottoms with welded or bolted draw rod bracket and welded frog.
Gerald J.
