180 headgasket ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 180 headgasket ?
    Posted: 17 Oct 2010 at 8:19pm
Just got a rough 180 that needs some work for a winter project ; it runs decent but when you have it idleing and go to the front by the air cleaner it sounds like compression coming thru , cant really feel it but it has a certain noise , noticed a little oil in the water; no water in the oil ; could it be a headgasket leaking a little ?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 9:15pm
Oil in the water - definitely head gasket.  Had that happen many years ago on my 175.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 6:33am
compression at air intake is leaking a intake valve(s).
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 7:55am
Could also have cavitation in the cylinder sleeves letting water in the oil, but that will usually keep letting water in if it sits for a long time, not just when it is running, but if it's just a slight leak, like past the sleeve o rings, then it could only leak when the coolant system is pressureized.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 10:09am
he says oil in water, no water in oil. Pin holes in sleeves will quickly fill the pan with water(coolant).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 11:51am
Oil in the water? I would be looking at an engine oil cooler leaking, unless this engine doesn't have one.
