bio diesel clean up
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Topic: bio diesel clean up
    Posted: 17 Jun 2023 at 10:04pm
The return line on one of my tractors that i recently bought was leaking, so I fixed it, but the previous owner had bio diesel in it, as it came from MN.  I started cleaning off the dried up fuel with E85, which does a decent job, but evaporates quickly, and can be hard on paint.  I'm curious if there is something else that others have used that would cling to vertical surfaces and dissolve the old fuel?  Brake cleaner doesn't seem to phase it, and it'd be nice to clean behind the injector pump, where it's hard to reach behind with a brass brush.  Thanks, guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 11:03pm
pressure washer ?
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 11:42pm
I've used a putty knife and scrape where it reaches, then get a can of spray engine cleaner, spray on cool engine where you want to clean, let soak until starts to dry and use a squirt nozzle on end of garden hose and thoroughly rinse off.
 A pressure washer works better but sometimes we use what we have available.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2023 at 9:10pm
Thanks for the ideas guys!  I tried straight simple green, mainly because it's what I had on hand.  It seems to work ok too.  Pressure washer is definitely the way to go.  Mine doesn't heat the water like it should now, one more thing to fix, Smile
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 10:32am
Dollar General oven cleaner. Used it on the final drive covers of my WD. 71 years of grease came right off. Didn't seem to hurt what was left of the paint.
Edited by exSW - 21 Jun 2023 at 10:32am
Learning AC...slowly
This page was generated in 0.174 seconds.
