37 wc transmission 49 wd clutch housing
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 37 wc transmission 49 wd clutch housing
    Posted: 11 Jun 2023 at 9:29am
will i be able to use the wc trans with a wd bellhousing i have lots of wd parts and i need the housing with a starter hole i think 12.1 compression will be a little harder to hand crank
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 3:37pm
You can use the WD bellhousing. We used a WD45 bellhousing on a styled WC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 4:22pm
thanks i will start harvasting parts from our bone yard will probley use that 201 block also
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 4:30pm
had a test and tune pull yesterday here sled was working well  because i ran the sled the full day but i did get one pull with my c at the end of the day against a allis b realy womped on it  but had just barely got it back from the other side  the 941 fords were eating the farmall m for lunch
This page was generated in 0.242 seconds.
