WC Valves and Timing
jshoemaker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jshoemaker Quote  Post ReplyReply Direct Link To This Post Topic: WC Valves and Timing
    Posted: 17 Oct 2010 at 3:12pm
Can anyone help me with how to set the valves and timing on a WC.  What is the measurement when setting the valves and is the timing set to TDC?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 6:31pm
Are you in the process of reassembly? If you had the cam out or the crank out, the cam has to be timed to the crankshaft first. What kind of ignition do you have? Mag or distributor?
If the engine hasn't been apart run number 1 up on compression stroke and set the valves .011 cold. They should be set at operating temp to .010. You can crank the tractor over one cylinder at a time to do this on each cylinder.
 I'm sure by the time I get this typed there will be others that answer your questions better.
