HD6G pinion shaft
MyHd6G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MyHd6G Quote  Post ReplyReply Direct Link To This Post Topic: HD6G pinion shaft
    Posted: 09 Jun 2023 at 8:45pm
Hi All,
I have aliis chalmers HD6G high lift I pulled the steering clutch and pulled the pinion shaft out and found the pinion gear is shot, was wondering if your able to pull the pinion gear out with out taking out the intermediate shaft and final drive gear out? Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 11:35pm
Pinion shaft would be part of the transmission that indexes into ring gear , and ring gear is flange mount to the brake/clutch drum .
 Which section are you in the final drive and 3 reduction gears in the outer housing ?
If so believe the only way it to drop all the gears out which means pulling the axle also
Post Options Post Options   Thanks (0) Thanks(0)   Quote MyHd6G Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 6:42am
It is the very top gear that has the shaft coming off the steering clutch, I got that shaft out and the gear drops down in, I can reach up from the bottom and grab it and will come down some but it doesn’t seem it has enough room to come out.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 7:57am
Did you try to turning the bulgear front in back maybe the pinion could go down or if you removed the top shaft cage and try to fisch the pinion and the pinion is 5 1/2 inch hight
Post Options Post Options   Thanks (0) Thanks(0)   Quote MyHd6G Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 8:25pm
Tried to get the gear over the bull gear it is just barely to big but it is not able to clear the housing, also the bearings measures 5”, wasn’t able to get it through the housing.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 8:36pm
This help?
That's All Folks!
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 8:37pm
I would suggest you pull the bottom cover from the final case and closely check the intermediate shaft for looseness. These bearings are much more prone to failure. There should be NO endplay or radial movement in this shaft.
Semper Fi USMC    1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote MyHd6G Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 8:41pm
The intermediate shaft is the shaft in between the final drive pinion shaft and the shaft that has the bull gear on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 9:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MyHd6G Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 9:12am
The intermediate shaft I did check it does not have slop in it, but I am still having problems getting the pinion gear out. I was reading in the book they said they slip the pinion gear in then put the intermediate shaft and the bull gear in, would that be the only way to get the pinion gear out?
