WTB Gear for M&W gravity wagon
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Topic: WTB Gear for M&W gravity wagon
    Posted: 03 Jun 2023 at 3:31pm
I have this gravity wagon with dual chutes and one door is missing it's pinion gear attaching to the hand wheel to operate the chute door. I think the wagon is a model 400 but not entirely certain. Good wagon and I use a chain fall or come a long to keel haul the door open to dump now.
I just need the pinion gear that drives the rack to open the door
Thanks for any assistance.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2023 at 6:02pm
See that I received a response to this request in the "Scam List" thread.
I still need this pinion gear.
Thanks,
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2023 at 9:43pm
Are your parts machined teeth? My Parker wagon has machined rack & pinion. I don't know if they still exist either. Check out hopper bottom trailer parts for something you may be able to adapt? Wilson used a R & P before the straps. Think Timpte has used similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2023 at 10:44pm
Yes, they are machined teeth. I think there are 12 teeth on the pinion gear and it looks like a #100 chain sprocket to me but it engages with a rack on the door. I can make something work with a length of chain and appropriate sprocket but was hoping someone had an old wagon no longer used they could part with this gear.
It plainly has cast into it "M&W Gear, Gibson City, IL", but they no longer support these. I get by there delivering to Pontiac fairly regular so stopped in and asked.
That's All Folks!
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 5:38pm
I needed one and found a 60 roller chain     sprocket about the right size   and welded chain to an angle iron.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 6:37pm
[QUOTE=DON G] I needed one and found a 60 roller chain     sprocket about the right size   and welded chain to an angle iron.[/QUOTE
Thank you. I deducted the same with a #60 roller chain sprocket, (3/4" pitch) and ordered two. One is an "A" type, the other a "B" and welded together they work well on the existing rack. It will be a lot easier than a crowbar to open the doors during grain operations later in the fall.
That's All Folks!
