I felt like dr p fitting this alt on my 200
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: I felt like dr p fitting this alt on my 200
    Posted: 01 Jun 2023 at 6:25pm
Lol…grinding and fitting grinding fitting grinding …on the alt case in order to mount the pivot bolt as the top of the case hit the thermostat housing. Once I could get the pivot bolt in and tighten there was plenty of clearance. Plus I had to “clock” the   alt 180* which was new to me. Ian and I made and mowed 3600 bales (40 lbs) this past week. Flying tomorrow. Thanks for everyone’s help! Dana
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2023 at 7:01pm
That's disappointing. I would have ASSUMED coming from D & B that it would have been a plug-n-play not needing anything. I'd be complaining if it was me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2023 at 7:11pm
A "replacement for"...UPGRADE.. but not EXACTLY the same size... . Maybe one was made to INCHES and the other was made to MILLIMETERS ? Wink
How did the TACH work out ?  everything screwed together and it reads correct ?
your ORIGINAL was a 10DN ...... that is the difference.. GOOD JOB !
Edited by steve(ill) - 01 Jun 2023 at 7:17pm
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2023 at 7:31pm
If you only knew how many times parts came to the operatories for " touch ups". Those diamond burs in a high speed hand piece can do some amazing things. Lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2023 at 8:09pm
I’ll try er out after my flight tomorrow😁
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 3:41am
D&B had a great price with free shipping si I bought 2.
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 8:53am
D&B equip is Excellent ............ Just a little TIGHT for this application... I would have thought SOMEONE would have told them about the interference fit since they DO advertise that this is specifically for the ALLIS tractor.....Its probably the only option with a TACH, but they could warn you that you need to "grind the corner of case".
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 8:55pm
Finished the alt hook up…and it seems perfect. Turn on that AC and she goes to work nicely. I bought 2 so we have another spare. Oh yeah tach worked good too.
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 8:58pm
great to know..... this should help THE NEXT GUY !!
Is the PIVOT HOLE in the engine block..  or could the bracket be LOWERED 1/4 inch to get room ???
Edited by steve(ill) - 02 Jun 2023 at 8:59pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 9:57pm
THAT took some shoehorn grease!  Nice job, Captain!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 7:15am
The "DN" series case is shaped a little differently than it's "SI" cousin. Doesn't surprise me that the "SI" needed a little mod done. That is pretty tight in there fir' sure though, even for the "DN"....!
Steve@B&B
