7050 hydraulic issues |
Wilczynskijr
Topic: 7050 hydraulic issuesPosted: 29 May 2023 at 9:37pm |
Tractor has has issues sense I got it. Put new cables on it. It has hydraulic fluid. Everything works just remotes only work half the time. And most the time you.misy move lever around to find sweet spot and they are very slow and touchy. I've tried adjusting and seems like nothing changes.almost seem to surge for hydraulic fluid. Are my valves bad or is it the pumpm itslef?
DrAllis
Posted: 29 May 2023 at 9:56pm |
How does the power steering work ??? What exactly have you been adjusting ??
Wilczynskijr
Posted: 30 May 2023 at 10:38am |
Power steering is not 100 percent.
DrAllis
Thanks(1)
Posted: 30 May 2023 at 11:14am |
Everything begins with the power steering pump. You've inherited the problem and have no idea when the hydraulic filters were serviced last. So, assuming the oil level is truly up into the TOP sight glass, I'd be changing the two hydraulic filters under the rear end. Make sure the left filter has the screen transferred from the old filter if it is even in there. If the screen is missing, that may well be your problem. Use only AGCO filters !!!! Get an owners manual, as changing those filters for the first time is a chore. Do NOT swap filter covers left to right. Right filter goes in spring first. Left filter goes screen in first. Until this area is 100% correct, you cannot diagnose what is going on with certainty.
MACK
Posted: 30 May 2023 at 9:35pm |
Sounds like you also have a lot of worn out linkage. MACK
