WTB : D14 ring gear carrier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: WTB : D14 ring gear carrier
    Posted: 05 May 2023 at 5:50pm
One of my brothers is restoring a D14. He needs a carrier. His is bad. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 12:53am
What’s the part number Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 5:54am
Differential "carrier" ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 9:11am
Did a lot of plowing with one spinning a lot? GET YER FOOT ON THE BRAKE BOY!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 9:37am
would that happen to be the same part as the D15 ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 9:40am
E-Bay..........
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 4:07pm
There were 2 different Carriers.
One with early D-14's that were 6 Volt.
Different Carriers for later D-14 that were 12 Volt.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 8:17pm
Yes, differential carrier. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 8:56pm
G
 What would that have to do with it? I can see different starter ring gears 6 VS 12.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 9:49pm
the piece that the RING GEAR is bolted to is called a "HOUSING" in the parts book and it never did change.... the term "CARRIER" is used by Allis to describe the "bearing holder" on each end of the shaft.... and there was a change after the SN 19xxxxxx .
If your looking for the "ring gear holder" it was always the same.. Many call it the "carrier"... except Allis !
Edited by steve(ill) - 06 May 2023 at 9:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 10:38pm
Steve, learn something new everyday.I need the housing. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 12:05am
I’m parting out a D14 that should have a good differential in it.
Owner of Matt Scott LLC
http://www.mattscottllc.com/
