7010 power shift noise
allis/cattle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis/cattle Quote  Post ReplyReply Direct Link To This Post Topic: 7010 power shift noise
    Posted: 02 May 2023 at 2:44pm
My 7010 power shift has a clunking noise in 3,4,5, and 6th gear. It was running fine till about an hour ago when I throttled back for a rough bridge crossing. I had throttled up and it started clunking. I stopped turned around and am now idling home in second gear as it don’t make noise in that gear
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2023 at 2:51pm
Place the tractor in PARK. Foot off the inching pedal. Shift progressively 1 thru 6, pausing at each gear to listen to it. Start with engine at 1200 RPM and if it seems quiet throttle on up to full speed. I'm not there, but I'm thinking a cab ground out/cab rubber isolator issue, not a transmission issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis/cattle Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2023 at 2:53pm
It’s not a steady clunk it speeds up with the gear your in
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2023 at 3:54pm
Did you do what I told you to do ?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis/cattle Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2023 at 4:05pm
Yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2023 at 5:18pm
So, if it still makes the noise sitting still in PARK (engine running), while running it thru the 1 thru 6 gears, it sounds like a transmission problem. But, I'm not there listening to it. Maybe drain the transmission oil and clean the pump screen and see what might be laying next to the screen.
