32 " rear tiller bearing removal
thatsmyallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thatsmyallis Quote  Post ReplyReply Direct Link To This Post Topic: 32 " rear tiller bearing removal
    Posted: 30 Apr 2023 at 10:40am
i am trying to to get to chain drive gear in rear tiller . i am having trouble removing bearings to get case apart. i have removed flange . from looking at online parts blowup there seems to be a washer called a shield that needs to come off before bearing. there is a ridge on shaft on top of bearing . im wondering if this is it and it is just stuck. when i took the case apart th chain was off. i put it back on reassembled and tried to use it. it would slip going foward. when i looked at drive gear the teeth were slanted . i assume they should be straight and it is wore out. any help would be appreciated as i wanted to try it on garden this year . thanks
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 10:19pm
the guys over on the simpleAc forum will know and probley know where you can get the parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote thatsmyallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 4:10pm
thanks for your help im trying but having trouble joining group
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 10:58pm
i did the chain and bearings on mine about 6 or 7 years ago  it didnot seem to be very hard just messey    i am going to put mine on in a few days and iwill look  to see if i can remeber how it came apart
Post Options Post Options   Thanks (0) Thanks(0)   Quote thatsmyallis Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 8:10pm
thanks
