easy way to move in d17 wheels
bwgill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwgill Quote  Post ReplyReply Direct Link To This Post Topic: easy way to move in d17 wheels
    Posted: 15 Oct 2010 at 8:12am
I have a D17 and need to move wheels in on slide bars, is there an easy way to do this
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 8:33am
Loosen all four eccentrics on the wheel, hold the brake on the opposite wheel, use the the engine and tranny to spin the hub in the direction you want, to extend the wheel.
 Getting the eccentrics loose is sometimes a problem if they haven't been work in years.
If that is the case you might end up disassembling the rim from the wheel center to clean and soak the rusted parts. Reassemble the eccentrics with never seize lube.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 9:20am
Here's a film from Allis on the WD45, It shows the wheel changing of a Allis.
Charlie, can you come help me set my tractors wheels for plowing you make it sound so ez. lol
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 9:35am
Got a clean cheap motel close by Don? I was telling Liz yesterday I need to go to Missery the first Sat of Nov. I'm not betting on being there though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 9:39am
Charlie - maybe Don will let you sleep outside in the "dog house" - seriously, you have to see his dog's house...lives in luxury I tell you.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwgill Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 9:40am
Thanks, I am going out now to try
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 9:40am
Yes there is lots of them about 15 miles from here or you guys can stay right here with me.
So just loadup and come one down!!!!
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 9:41am
BWGILL - do you know if it's a Series III or Series IV D17 - those will be much easier as the rim clamps for the rails are much improved.  Also at least one of the rails should have holes in it for stops on each side of the center.  You'll have to remove those.  The bolts can break off in those if they have rusted and been sitting a while so spray some good penetrating oil and maybe use some heat on them if they they don't seem to want to turn.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 9:53am
Mike Is this the dog house you are talking about? its a two room heated 8' x 8' house just for one dog. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwgill Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 10:07am
I have a series III, and have the stop blocks removed. Do I need to loosen all the bolts on all the slides
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 11:16am
You don't loosen any bolts. There is an eccentric lock that cams up against the rail on the rim. All 4 of these need to be backed off about 180 degrees to free the rail. Then the rail can slide through the four forgings that contain the eccentrics.
 Look at the wheel center. On the outside diameter of the wheel center there are 4 forgings bolted to the wheel center. On the outer part of these forgings is one hex centered in the forging. That is what needs to be turned to the left about 180 degrees. There is a small protrusion from the base of the nut that limits the travel. Turn it as far to the left as possible to loosen and they must be turned to the limit right to lock,
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 11:28am
Don, that film makes it look real easy too.
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 2:40pm
Since your tractor is a series III, it should have the single bolt through the eccentric.  Loosen all four, one side of the tractor at a time...do not remove nuts or bolts.  Start the tractor, put the tractor in low gear or reverse (depends on which wheel you are moving) and hold the opposite brake. The earlier wheels, prior to series III had the cast design (no nuts to loosen).  Good luck.
Chad
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 8:38pm
thats a cool video
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 9:44am
Don --Great video --- makes me want to run out a buy a WD45. Wait - wife has hid the truck keys - LOL
This page was generated in 0.127 seconds.
