D-14 Oil Sump Plug
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: D-14 Oil Sump Plug
    Posted: 14 Oct 2010 at 11:10pm
I found a D-14 that had a hard life.  It's getting better and now runs and I can mow with it.  However, I need to change the oil.  The oil sump plug is frozen and now the head is starting to get rounded off.  I find it hard to believe since it should be well oiled.  Anyway what can I do to remove this plug??  Thanks in advance for any advise.  Going orange is going great!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 11:23pm
Try  a  6 point socket first if it is a hex head.
If no luck, then a pipe wrench.
Gary
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 6:36am
Early ones where a pipe thread,someone thought it needed to be tighten until it could not turn .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 6:37am
If it is the pipe thread one ,I have put a nut over it and welded it fast to plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 9:32am
Water will settle to the bottom of the pan and if the tractor wasn't run for a time the water can rust the threads. Get the plug out and clean the threads in the pan and replace the plug. If it is a NTP thread you can get plugs with a 3/8 square female type socket instead of male. Then you can remove them with a 3/8 ratchet. It would not hurt to add a touch of grease to the threads when assembling.
This page was generated in 0.289 seconds.
