wider front tires on series 1 d17
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: wider front tires on series 1 d17
    Posted: 10 Apr 2023 at 9:07am
looking at putting 9.5 x 15 four rib or diamond tread tires on front of series 1 d17d wondering if some has done this, and how it looks ? should only be 2 inch taller but that should be ok with 16.9 x 28 rears   ,
Model 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 4:57pm
That’s what I have on my series 4 and I think they look great. And they function well also. 4 rib.
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 5:43pm
On a wide front it is fairly easy to do. Find the correct offset rim and go with it. If you have a loader on your tractor, use a 3 or 4 rib tire so it will turn in the mud. Do not buy wagon rims to put on the front of your tractor. The centers of wagon rims are far lighter than tractor rims and with a big loader you will actually break the centers of the rims. I've seen it many times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 6:26pm
stock rims... or your buying wider ?? ...... how close is present tire to the king pin ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 11:04pm
model 70 what are you useing for wheels and are your hubs 5on5 like the series 1 , think its going to be easyer to get  new hubs from somthing that are six bolt to find wheels or  will probley have to make wheels with rims and centers  ,  hoping someone on here can just say go buy this and this  instead of searching hunting gathering and , biulding    i would like to see a picture
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2023 at 8:42am
If it's not a series 4 there is a very high probability you have 5 bolt hubs which makes finding wider rims pretty tough. I had a set of 9.5Lx15's on Buick rims but they are sold.
This page was generated in 0.101 seconds.
