620-720
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: 620-720
    Posted: 23 Mar 2023 at 8:14am
What is the main differences between these?
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2023 at 7:29pm
Dave, the one major difference I noted is the front axle on the 720 is heavier duty then the 620 although some of the early 720s still had the lighter duty axle.  Know a couple other items escape me on the differences.
IB (restoring), MF GC1705, MF 2705E
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2023 at 8:29pm
Biggest difference was decals, but the 720 came with more options available
Edited by AC720Man - 23 Mar 2023 at 8:38pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2023 at 10:05pm
a bunch of the pto stuff is differant if i rember right but mine is a 616 with a lot of 720 stuff on it
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2023 at 8:32pm
I’m not aware of any implement differences. 2,000 rpm pto throughout the series. I have a tiller from the 616 era that works perfectly on my 720.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2023 at 9:42am
616 started out with multi piece/hanger bearing PTO shaft from engine to transmission and downdraft carburetor 16 hp Onan.  620/720 are one piece PTO shaft and have side draft carburetor 19/20 hp Onan.  Same internal spline PTO connection for implements.  616 and early 620 also had narrower rear fenders.
LindaJohnson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LindaJohnson Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2023 at 6:23am
Which one is better? There is a significant difference.
Edited by LindaJohnson - 18 May 2023 at 1:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2023 at 10:37am
720 with the heavy duty front axle if using a loader otherwise the 620 will do fine.  620 I had handled everything including the 52" snowblower.  Used the snowblower and 60" mower on my 400' drive plus areas of our association common 1 mile driveway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2023 at 8:21pm
Looking at 616 what are the bad parts of this tractor 16 hp vs 20 and other things???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2023 at 9:27am
The wiring is a little different on 616 than the 620/720. Also the charging system is better on the 620/720 models....
Steve@B&B
