Help with welder purchase
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Topic: Help with welder purchase
    Posted: 13 Oct 2010 at 5:58pm
I've come to the conlcusion that I need to break down and purchase my own welder for my ongoing AC tractor projects. With my limited welding experience and not really wanting to spend thousands on a set up, it seems a mig, with it's wide range application would be the direction I should go. I've been looking at the Hobart welders at the Rural King. I've heard they are nice welders for the money. Looking for advice, tips, any and all comments appreciated. Thanks Ron
CA Tractor
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 6:22pm
I have a Hobart 220V MIG but I bought it mostly to weld up a dune buggy frame, light tubing.  It is easy to use but to get a good weld the steel has to be pristine clean and no wind.  For a farm welder I always wanted a AC/DC stick,  probably more versatile.  When I was growing up we made due with AC buzz box for everything.
Wish I was better with TIG and brazing all that stuff but never worked at it enough.
Oh forget flux core wire.  My welder came with a spool of it, I used it for about 15 minutes and thought it was a crappy sub for a stick welder.  Got a tank of weld gas and have been fine since.  Big 220V MIGs do some serious welding but my small one is not in that class, I think it is the model they call a 185 and does respectable job to 1/4" but demands a good prep.  Much more it is hard to get enough heat into it.   Mine only draws 20amp max at the wall so you have limited power even for a 220V compared to a stick welder.
Edited by Rick of HopeIN - 13 Oct 2010 at 6:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 6:24pm
I've had a  225Amp AC only 'stick ' welder for the past 24 years.Only use 7018AC rods.Fixed or made everything from lawn tractor decks to very heavy duty trailers. It was the best $200 I ever spent.I've heard MIG is great for thin tin, 'sticks' better for 'real steel'.Then there's the flux cored wire or bottled gas MIG decision. My guess it depends upon how much you want to spend for a machine that will do your types of jobs.
I'd like to have  a small fc MIG for the thin tin jobs but have used 'the beast' with small sticks and low amps to do thintin work.
Just some ideas for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 6:26pm
I would recommend getting a 220V machine. I have a 120V machine and it's fine for sheet metal work. For the bigger stuff, I either have to preheat the metal with a torch or break out the old stick machine. I'd stay away from the flux core type machines. You'll never be happy with the results.
Edited by Brian Jasper co. Ia - 13 Oct 2010 at 6:29pm
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 6:31pm
go 220...for easiness of running get a miller 185, 210...will weld most anything, and easy to set up....set your top and bottom dials about the same way and you're pretty close....start welding....I have a 185, it was replaced with the 210. Hobart builds a nice machine as well. Miller, Lincoln and Hobart and ESAB are the best of the best.....
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 6:44pm
Like any tool , buy the best you think you can afford then spend a few $100 more to get the next couple steps up , only thing with a welder it can be a lifetime investment so buy more than you think you need.
 A machine that is AC only will work for most things but is limited using 6013,6011, and some 7016 or 7018 AC rod., Buy something that is 220 V. If you want to go to the next step then a AC / DC machine is next in line. Will weld with 6010P , and all 7018 rod.
 Most good welders that are in the price range are now Inverter Welders with a rectified high frequency unit then diodes to change to straight or reverse polarity. This also gives you infinate output control, the old front tap machines with pre-set plug in or dial set by transformer taps are out now as good machines to buy.
 Wire feed welders with the capacity to also SMAW weld would be my choice , and something to run minimum of .035 wire E70S grade. Wire feed does not work well on rust or non clean metal , thickness of base metal should not be problem as weld area is ground to make multiple pass welds.  Using Argon/CO2 shield gas and be sure welding gun is rated at over or at same maximum amps as machine highest output.
 Next would be a machine that will TIG weld also along with the SMAW, and GMAW welding,  now you are into some money but well worth buying all you can now rather than updating later.
 Get a Speedglass welding helmet (3M product), self darkening as it is well worth having, get a good one with the variable shading and the delay cycle.
 I have a Miller AC  180A unit i bought in the 60's, a 80's Pow Con 250A Inverter that will SMAW, GMAW and TIG, as well as straight or reverse polarity.. latest is a 2000's, Miller 304 with all the same features but built in high frequency , foot control on TIG, water cooled torch, and more bells and whistles then I have used so far but welding with it is a breeze.
Edited by Coke-in-MN - 13 Oct 2010 at 6:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 6:48pm
I have an old Forney AC welder and I would like to see somebody weld with it using 7018. I have never been able to use it. 6011 or 6013 is all I use for the "farm" repair work. I have a ton of it that was thrown out at work years ago so I'm set for life for rod. My SIL is a Boiler Maker and he thought I needed some 7018 rod so he brought some home for me. I told him it won't work and he proceeded to "show me how" to use it. He couldn't believe it wouldn't work. He couldn't do it either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 6:57pm
Chuck get the 7018 AC rod, it has a different flux and works either AC or DC and either polarity. I had a can of Lincon 7018 and could not run it on my 180A Miller , then bought some ESAB 7018AC and it ran fine, figured that Lincon rod was bad but when I got my Pow Con machine it worked with no problem.
 I put a full wave bridge rectifier on my 180A Miller and then the Lincon rod would run on that also.
Edited by Coke-in-MN - 13 Oct 2010 at 7:00pm
Doug northern IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug northern IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 7:05pm
Ive been welding for years with 7018 it all i use .  Have a miller syncro wave 250. also a hobart 140  wire feed for light stuff.
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 7:17pm
I have a Century 220V MIG wire welder that I use all the time. I also have a 120V Century wire welder. I used flux core wire with the 120V welder, but I MIG weld with the 220V welder. The 120V model was not really big enough when it came to most projects. The 220V welder will go to 165 Amps and is rated for 1/4" in a single pass. With multiple passes on thicker metal it will weld all I need.
Most places seem to have gone from Century to Hobart. I have never had a Hobart welder, but I have used some Hobart wire. Hobart makes good stuff, but if you can stand the expense Miller is top of the line.
One thing I definitely think is worth your money is an auto darkening helment as mentioned by Coke. I went with a Kobalt helment from Lowes. It was not the cheapest one, but it is protecting your eyes. It was amoung the best money I ever spent.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
RickUP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickUP Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 7:23pm
If stick welding is your choice, then get an AC/DC lincoln. If you plan to do some wirefeed also get a Lincoln that will do both. (220 volt). Now when it comes to rods, get Esab 7018. When buying wire you need to spend a little to get enough nickle content, it will pay off in the end. Cheap wire can be used for haywire repairs till you get sick of it. Lincoln can make welders, but their rods and wire suck. Good luck.   This reply is aimed at mild iron type welding only.  But with the right machine and a little training you can weld almost anything.
Edited by RickUP - 13 Oct 2010 at 7:57pm
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 7:31pm
Just for your information, Hobart welders are owned by Miller welders, probally thier cheaper line. Was told this by a Miller rep.
Clay in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay in MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 7:53pm
An acetylene torch set for brazing, heating, bending and cutting and a used 220V stick welder have handled all my farm welding needs.  Stick welders seem to last forever and you can often find them barely used for very reasonable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 8:00pm
I have a Miller 220v Millermatic 212 wire welder and love it but for the heavy or field work I have a Thermalarc Predator gas engine welder generator comparable to a Miller Bobcat, best investment I ever made as I can power the house off the generator or weld in field when a I really screw up!!  Wire is for clean welding where prep can be extensive, the good old 7018 comes out for the down and dirty work.
klyant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klyant Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 8:04pm
You want a 220v.  I have a Miller 200 it works really good unless the wind is blowing. Wind blows the co2 away and then the welds cool to quickly.
Jamie (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 8:20pm
Bought a Miller Thunderbolt 220V AC/DC stick welder about a year ago. I don't weld with it enough to be considered "good" but I am "good enough". LOL Gave a little over $600 for it and figured it will do all that I need. Usually us 6011's just for basic farm stuff. I'm definately not an expert, but that' what just about always used and seems to be working for me. I have a box of 7018 AC rods but not sure which I like best.
The biggest thing that has helped me is the auto darkening helmet. I bought it the same day as the welder but I got it at Harbor Freight. It was only about $50 so I wasn't going to loose much. It has blue flames on it but I don't care. Turned out to be a pretty good investment. Besides, it's worth a good laugh to see my dad wear that helmet. He never has struck me as the "blue flame" kind of guy! LOL
Just when I thought I was finishing my "honey-do-list", she turned the page!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 8:34pm
i have a Miller thunder bolt 220 volt, 180 amp AC/DC stick welder also. VEry nice. THe 6010 rod is a deep penetration rod to burn into  rusted or dirty metal. Flux looks pretty poor after welding. 7018 rod is a nice finish rod. Metal should be mostly clean to start with, littel rust, wire brush surface. With 7018 you should be able to tap on the flux after welding and it just falls off easy. Very pretty weld when done, if your a good welder.  I gave up on the 180 amp AC lLincoln buzz box about 20 years ago.
    I have a lincoln 135 amp, 110 volt wire feed with gas. I use it on hoods, fenders and sheetmetal. Works good for me.  THe boy is not as experienced and i started him out with a 185 amp 220 v Miller wire feed with gas. HE can weld sheet metal up to 5/16 plate pretty easy. DOnt have to be an expert to make it look good with a little practice.
bluebanshee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bluebanshee Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 8:37pm
We have 3 welders. An old Lincoln Idealarc250 that we still use occasionally and still welds great. Have about 70 feet or more cable on it so we can weld nearly any size project and it doesn't have to be in the garage. With a small enough rod you can weld sheet metal but it doesn't look that great. Used about 10# of rod with it over the weekend, 6010 then 7018.
The mig is a Lincoln power mig 300 (310 amp) it will stick, tig scratch start and mig aluminum also with its 50ft python push pull gun. Lowest settings I can still mig car panels with 035. It gets used about half the time.
The tig is a Lincoln precision tig 175 (square wave). Its a little small for some of the stuff we do. It is a high frequency machine so there is no scratch starting. We changed it to a thumb control and it makes it much easier. With a tig you can weld nearly anything from pop cans, wheels, bolts, etc. Its slower but you have complete control over it. You can use just the torch without filler wire on some stuff. It takes time to learn how to tig well, especially aluminum but you can do so much more. Although it is much slower just like stick is compared to a mig. This machine also stick welds nice. If we only had one machine I think I would have to pick this one because it will weld the thinnest of metals and on stick can weld the thickest.
The speedglas auto darkening helmet is nice. It has a LARGE viewing area, much larger than many other helmets and is extremely lightweight.
Edited by bluebanshee - 13 Oct 2010 at 8:42pm
bigallis1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigallis1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 9:20pm
Ron, I would suggest getting a Mig 220 V welder.They are great for ease of use and all around welding. Spark's are more confined.
I just picked up a Millermatic 180 w/auto-set. Got from a local welding school/shop where I took a mig class.
I would also suggest taking a class in Mig welding, if nothing else, for safety and understanding the process.
Good luck.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 11:04pm
   35 yrs ago when I was looking for a mig welder the salesman told me that he could teach a person to weld with a mig welder in about 4 hours, compared to several weeks with a stick.  Also it's about as easy as operating a caulk gur.  Haven't had to use a stick welder in years.  A welder is a lifetime investment, get a good one.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 11:54pm
I have several welders, a century 180 ac/dc which I used for years then I got a little Lincoln 125 or 150, can't remember, 110volt wire feed.  Very handy for patching things where only 110 volts are are available.  Got a Miller 251 wire feed a few years ago (220 volt).  It is so easy to use and makes even my welds look good.  It is hard to use outside on windy days tho.  I buy the 44 lb rolls of wire, much cheaper per foot then getting it in 10 lb rolls.  I heard somewhere that Miller welders have copper coils and Hobart uses aluminum wire to keep the price down.
Allis Express participant
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 8:47am
I just bought a Miller 211 auto-set with gass. I like it a lot but am still challenged with burning trough 18-24 gauge material when butt welding. I need the class mentioned above!
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 9:03am
Hell I can teach a stupid monkey to well mig in 4 hrs.  Problem is that its the hardest to master, especially for thicker applications.  A mig weld can look perfect and be little better than glue do to lousy penetration.  I have not met a person yet that has always used a mig welder that welds well.  They don't look at the puddle and understand penetration.  There is a difference between making nice looking mig welds and good welds.
I always recommend an old miller dialarc or lincoln idealarc.  They are either 250 or 300 amp dc industrial duty arc machines.  They are bullet proof, I have never seen or heard of a failure(although I sure one or two out there have).  The good thing is that you can buy them for dirt cheap used off of craigslist if you are patient and wait.  Sometimes welding shops will know or sell used ones as well.  Make sure its a single phase 220v machine and not a 3 phase 480 or something like that.
A dc machine is not necessary but is much nicer to use.  Starts easier, smoother welds. In arc welding, if your welds look nice, chances are they are good.  Unlike mig, porosity and bad penetration look bad, can cover it up, tells you, grind it out and fix it.
If you are buying new, get a miller thunderbolt in ac/dc.  While the lincoln tombstones are durable welders, I don't care for their limited adjustability, although many use them with no issues.
If you are not going to listen, I will tell you about some mig welders.  First get a 220 machine.  110v is only good for thin body work(might be good to have a 110 machine along with a stick welder for heavy work).  Hobarts welders are identical in many models to the miller.  In the smaller models, a few years ago at least. Some of the rolls and wire feed mechinism in some but not all of the hobarts were plastic vs steel/aluminum in the miller.
If you are an occasional user of mig welders, you only want small rolls of wire.  Not using the wire consistently will surely result in rusty wire that you will have to throw out.  If your garage has moisture, good luck almighty.
Welding rod should be kept taped up in the plastic tube until you need to use it. Get a tube with screw on cap that holds rod your currently using.  7018 especially.  Old 7018, especially if its around for a while should be put in the oven at a few hundred degrees for a few hours to drive off the moisture, I do this if its especially wet out or the rod has been setting for several months, then it goes in my sealed tube.  Rod ovens are nice but are a little salty and drive up the electricity bill, and are not necessary unless doing pipeline work.
Take a class at the local community school/some high schools.    They will show you the proper way and you will get to cut up welds and test them to show you how mig can look so good and be so crappy.
I personally have a Miller syncrowave tig/stick machine.  I use stick 90 percent of the time.  The tig on medium thickness precision jobs, stainless, and aluminum. I paid about 1500 for it, but waited for a while for a good deal to come around.  Very few people need its capability and I would have to say that its digital controls make it suceptable to expensive repairs down the line compared to an old stick welder like the dialarcs and idealarcs.
I still use an oxyfuel torch to weld chromemoly tubing, body panels,  braze, and thin shaped aluminum sections.
Edited by firebrick43 - 14 Oct 2010 at 9:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 3:24pm
I have a nice Airco Tig welder with recirculating tank I would sell. It also has a spot weld attachment for sheet metal. Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 3:54pm
Any welding is PRACTICE, PRACTICE, PRACTICE, this is where the school comes in , learning to make a puddle.  Vertical up or overhead is where the challenge comes in .
 Butt welds need prep in v in metal to make good weld.  SMAW is done in most palces where any air movement will effect the shield gas on MIG.
 The Speedglass has a large view window which is reason I bought that, and like any good tool it needs proper care and handling . (don't be dropping or throwing it around.)
 Most of the AC/DC machines now are inverter (step up transformer with frequency change) then brought to welding voltage and amp range.
 My Pow Con was over $1500 back then and is similar to Thermoarc machine.
The Miller 304 complete was near/over $5000. Just wish I would have bought the spool gun but that was another $1000
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 4:46pm
Coke, i'm with you on the Miller 304. Awesome machine!
As for the beginers welders, I would advise going on and spending a little more on a better machine now, rather than having to turn around in a year and do it anyway.
If you want something for general welding of mild steel to moderate thickness, go with an AC/DC stick machine, 220 volts supply. The inverter machines that Coke mentions do work much nicer than the older ones. You should be able to pick up a pretty nice used one. JMO, but I would go blue(Miller). I have had a few bad experiences with component failures on Hobart and Lincoln machines.
If you want portability, go for a mid-range engine-welder. Miller Bobcat 225 or 250. I prefer the NT series over the G series. I also prefer the 250 over the 225. Much smoother machine.
A nice smaller engine welder is a Miller Bluestar 2E. I bought one for $200.00 last year. It welds much better than the Lincoln Ranger 8 that I just got rid of.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 5:31pm
i will have to go along with cokes summation of info.DONT TRY TO ECONOMIZE GET A GOOD ONE FROM THE GET GO.i have a 1450 hobart,a 140 hobart wire welder and a airforce 400 plasma cutter,like them all.was amazed at the way the 140 runs aliminum wire.the main thing welding alum.is to use a clean ALUMINUM brush to clean the base metal.no metal wire brush.getting the machine fine tuned for alum,can be somewhat nerve wracking but it does a good job of it.also i use a wire oiler in my wire machine.really helps.on my wire welder i keep a 50 watt light bulb in close proximity to the wire spool.keeps the rust off the wire
realolman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote realolman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 5:55pm
I think any time you can afford it, get a Lincoln.
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 7:36pm
Thanks all, for the advice. I may look into the stick welder a little more. I really don't need a high dollar professional set up with the limited use it will receive. General hobby farm/repair, minor fabrication, but want to be able to weld sheet and the big stuff. Can I get a mig that can do everything, say a Lincoln ac/dc 225 can do for under a grand? Tracy, I think with my limited experience a tig would be way out of my league. what would you be asking for that set up? Thanks, Ron
CA Tractor
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 7:44pm
I have a Hobart 125. I have welded anything that I ever needed to have welded on the farm. Plow lift couplings for my 2 bottom roll-over plow. Ramps for a trailer to haul a JD 450. etc. I don't use gas, just wire. Bob
