8070 Powershift |
Post Reply |
Dean/MN
Orange Level Joined: 14 Sep 2009 Location: Oak Grove, MN Points: 740 |
Posted: 12 Oct 2010 at 9:47pm |
Having a hard time shifting from low to high on an 8070. Is it an adjustment or may it need a new cable? One of them was replaced recently. It's kind of slow on the road in low range!
HD16,917H,185,7050,8030FWA,8050FWA
klinemar
Orange Level Joined: 14 Sep 2009 Location: Michigan Points: 8026 |
Take the panel up in the floor and see if the shift cable is moving the transmission shift lever freely.
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8657 |
On my 8050, it was kind of tough getting it out of low range, also. Learned a few tricks to it. I don't know if you realize it, but putting the clutch tight to the floor applies a transmission brake, so if you put the clutch all of the way to the floor for a second, then release it part way and shift it out of low quickly, it will usually go easily. Also, if you are rolling slowly, put your foot on the clutch, but not all the way, then shift it out of low, it'll usually come out easily. Hope this helps. Darrel
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20980 |
An old/stiff cable on the range shift lever can make the effort very high and hard to shift. Replace the large cable and I'm sure you'll see and improvement.
Jim in SE ND
Silver Level Joined: 19 Jun 2010 Points: 61 |
My 8030 is that way like it drags alittle, not the handiest but if I shift to reverse then the range shift works good. takes pressure off I guess.
ScottinSWIL
Silver Level Joined: 30 Oct 2009 Location: Randolph Co. IL Points: 118 |
Yes , the reverse trick helps also on our 8070 when shifting back into park.
Post Reply | |
