WD 45 wiring
Rod in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 wiring
    Posted: 12 Oct 2010 at 8:46pm
 HI Guy's I have a WD45 that i'm switching over to 12volts Genny and a 12 volt reg.It has a pull rod for the starter installed a new key switch . Bur want to use the old light switch the bulbs are changed over to 12 volt . would it be easer ti get a cutout and switch over to 12volt . It has a distriutor on it Do's sone one have a wiring diagram for this .
Thank You Very Much
Rod in MN
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 9:57pm
You will need a 12 volt coil and condensor.  Lights should be ok if you already put 12V bulbs in.  Should not have to make any changes to the wiring after this.
KC-WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 9:56am
 I use a resistor to the coil. Starter shure spins with 12v.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 10:23am
Hi Guy's yes the coil and points were all changed over to 12volts.just need wiring diagrame
 Thank You
Rod in MN
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 12:46pm
Here are the wiring diagrams I like to use. they work out pretty well
wiring diagram
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 6:58am
We can fix ya up with a complete 12V conversion kit if interested. I give you everything in the kit to do a pro wiring job except ambition. That you have to supply.  LOL! Drop us a line, be happy to help you out.....
