aetna clutch release bearing
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: aetna clutch release bearing
    Posted: 01 Mar 2023 at 9:23pm
I know it's new & packed tight with grease, but I can hardly turn this throw-out bearing by hand.Shocked Should be a good brand it's even written in my original  service manual . It's for a d 10. Anybody had any experience with this??   thanks in advance, keith so.va.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 9:27pm
You have it pressed onto the shifter sleeve ?? or are holding it in your hand trying to turn it ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 10:20pm
in my hand
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2023 at 4:43am
I think I'd assemble it and give it another turn test.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 2:46am
Ok I pressed it  onto the shifter sleeve and the rear part of the bearing turns fine. I didn't realize on a throw out bearing there are two bearings. The front thrust face is the one that is tight. maybe the pressure of pushing against the release fingers will make it turn, thanks keith so.va.
