Reassembly ED40 Gear Box , Need Help |
Post Reply |
John426
Silver Level Joined: 14 Aug 2012 Location: France Points: 291 |
Posted: 23 Feb 2023 at 4:04am |
I am reassembling the gear shift of my ED40 gear box.
how to insert the rod shift and have the springs compressed? It is difficult doing that with only 2 hands? How to proceed?
Edited by John426 - 23 Feb 2023 at 4:04am |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22463 |
never ever done one but... GREASE ! use thick grease to hold ball and spring ?? I'm sure someone here will post his 'trick'.....
steve(ill)
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 81175 |
is there a vertical pin hole to push the balls in, then slide a wire thru the pin hole to hold 3 balls.... then pull the wire out after rod is installed ??
MACK
Orange Level Joined: 17 Nov 2009 Points: 7664 |
Make a T handle the size of rail. Grind a tapered V in the end to start over ball and spring. Start shaft through holes with ball and spring. Rotate shaft to push ball down. Move to next one and do same thing. Next push tool back out with rail and forks as they are to be assembled. MACK
Post Reply | |
